To enhance engine starting, I choose to use a cable to ground to the starter motor body, that also being the engine block, and from the engine block to both the firewall and frame. In addition, I run one #8 ground wire to the areas where lights are located at front and rear of the car. Obviously none of this is "stock" but it improves and maintains the performance of the electrical system.
