twostickmutt
The rear window seals in my 39 deluxe coupe each has a small curl in each seal. It's got no better and no worse in the 2 years I've had the coupe. Is there any advisable adhesive i could put a small amount under the seal to flatten it out. I'd like to keep those seals in place but if I need to change them I will . one more question ...is there any particular spot the molded mark on the seal has to be ? Thanks
