I've installed a 525 twice. Once in my 46 Ford, and once in a 47 Merc. I used a Borgeson (I think that's how it's spelled) U-Joint. A single U-Joint worked fine. It fit the star on the 525 and was smooth round for the steering shaft. I cut the stock steering shaft to fit into the U-Joint. I also cut the outer tube short enough to clear the U-Joint. I made a collar to fit inside the tube and to hold a bearing. The bearing fit the steering shaft and was secured by the collar. The shortened original column is then secured by the column drop at the top, and a homemade brace at the floor. Note that the stock pitman arm will fit onto the 525 box. Any questions, please email.
