Before criticizing the part because it is a reproduction you will have to determine if the problem is in the part, the hood or the installation.
First to examine is the hood. If the hood has been tampered with or repaired at the rear hem where the sheetmetal folds over the rear hood mount brace. If it has, that is a sign of potential problem.
Second place to look is the hood to hinge mount panel this panel should be positioned tightly against the hood sheet metal , if there is a bow in this bracket to the center of the hood the alignemt of the arms will be disturbed.
Third, at the attachment point of the hood hinge arms to the hood ther should be a 3/8" x 1/4" threaded shouldr that sticks off the hinge mount panel. this shoulder is the bushing that the hood actually pivots on. If this shoulder is worn or rusted off the hinge mount panel you will have to construct a new hinge pivot using tubing as a spacer so you can get the hinge to rotate properly.
Fourth position the hinges on the body and view the hinge front to rear. Position the arms vertical and insure that the arms transition perpendicular to the firewall as the operate. If they are bent inward or outward as the rotate they will bind on the hinge mount during opreation and will not allow the hood to fall on the cowl.
Fifth, use the correct short 1/4" hex bolts for the hood hinges, if you have a stepped bolt with a shoulder it is the wrong bolt and will damage the hood.
