39-40 coupe struts
I would like to adjust my stance. Making the rear higher. I’m thinking an adjustable strut could replace the tube shocks and get the look I’m seeking.
I don't think struts would do what you want. "Air Shocks" would do the job, but then the ride usually gets really hard. They're used mainly for increasing the load-carrying capacity
30-39: Can you post a few photos of your car's current stance and what the rear suspension looks like? Is it stock? Can you count the number of leafs?
It may be that your OEM transverse rear spring is worn out, like a broken main leaf or the incorrect spring was used to replace the OEM spring. You could install longer shackles, also.
Not sure struts and the original spring would play well together. At the least it would be a very stiff rear suspension. Lots of ways to change the stance of a vehicle, post a little more details on what you currently have and where you wanting to end up.
Here’s a old pic. Sorry can’t get pic of underside.
If you have a good set of original shocks they do quite well. As for adding tube shocks, there are brackets that show up on ebay quite often for the rear of 35-40 cars and trucks.
He said above that already has tube shocks; this is why I mentioned "air shocks". Shocks are shocks; struts are springs and shocks in one. I, for one, would not ask one to do the job of the other.
30-9
My 39 Air shocks pic, hope it helps. Obviously, I don’t extend it all way up.
Perhaps I.m missing something as I am not clear as to what you really want to do and what type of suspension you already have under the car.
Hi Fordy - it’s stock springs with tube shocks. Was looking for easy way to raise rear. Looks like air shocks are way to go.
I also have air shocks on the rear of my 48. Monroe air ride or something like that. They lift the rear just enough, due to the weak springs. Have to keep an eye on the pressure, tho as they leak down in a week or two.
Al Hook
At one time they had what were called helper springs that looked similar to a coil over.
Looks like they call them load levelers or load adjusters.
