Hello again:
Thought it would be best to start a new thread RE: cable brakes.
I know '37 and '38s have cable brakes, but have also heard 'cable brakes in conjuction w/ 'floaters', and kept well adjusted can function almost as well as 'juice' (my 39) brakes'.
Would probly like to keep original cable brakes, but not familiar with the term 'Floaters' and what their function is. Can any shed any light on this? would be much appreciated.
thanks,
John
Allow me to make a correction to your statement that cable brakes can function
ALMOST as well as juice brakes: With floaters, and properly adjusted, cable brakes will perform
BETTER than any Ford juice brakes up to at least 1948. Cable brakes will also be more reliable than
ANY juice brakes up to dual master cylinder brakes.
About floaters, their function is to permit the shoes to float as Ford intended, thereby becoming self energized. How this is done is to convert the adjuster from a wedge type adjuster ( Hotchkiss, adjusted with a wrench) to a star type adjuster (Bendix, adjusted with a brake spoon). The Hotchkiss design with wedges does not permit the floating action sufficiently to be self energizing every time you apply the brakes, as the components are "wedged" tightly against each other, preventing any meaningful movement, almost being in a fixed position. The Bendix Star type, is not restricted in its movement at all, meaning that the shoes are absolutely free to move, providing the desired self energizing effect.
Flathead Ted has designed a wedge floater for the early Fords, before 1937, that performs better than the original Ford wedge. The early Fords could not accommodate a Bendix type adjuster, so his product has gained favor for those early Fords, but due to its retaining the wedge design, cannot perform near as well as the star type in '37 - '38 brakes.
