38 pickup wiring question
LM44S
Does anyone have a a wiring diagram of the light switch bail on a 38 pickup? I think I have a wire on the wrong terminal. Thank you for your time.
That is easy to mis-wire. This drawing which I refer to as the "Green Switch" ought to make everything clear as mud about the switch's wiring. The second picture shows the BRASS-LOOKING piece that actually does the moving when you twist on that ring around your horn button. Figure that the three dimples in the brass ring fit into the three dimples that make-up the three points of the DOTTED TRIANGLE on the "Green Switch....WHEN THE LIGHTS ARE OFF! The two protrusions that you twist to operate the lights should be straight UP and DOWN at 12 & 6 when the lights are off.
BE CAREFUL not to mess-up the phenolic disc as seen in the third and fourth pics, as they are extremely hard to find by themselves. A cleaned-up ORIGINAL is about as good as it gets! DD
477051
477054
477052
477053
Thanks all for the help, I will have to take a look at mine later. Have to go watch my granddaughter play basketball this afternoon.
Thanks for the help guys, figured out I had a couple wires going into the head lights hooked up wrong
