38 ford juice brakes
melisa
Bought a set of 39 ford juice brake master cyl and clutch pedal assy, to install in my 1938 coupe. Does anyone have a picture of the completed project. If you could post it I would be very grateful. Tks Melisa
This is for a pickup but I'm assuming the car would be the same. As I remember I used the existing rear mounting holes and had to drill new holes at the front to bolt the '39 assembly in. The pedals lined up perfectly with the floorboard. The clutch pedal linkage was too far to the left. I just made up a longer clutch shaft to correct this. You may want to heat and dimple the frame to allow more clutch travel as the pedal arm can hit the frame when fully depressed. I didnt do this but I wish I had. It just allows for a little more adjustability.
