38 Ford hood latch???
chrisp
Greetings! I'm new to the forum and I'm really hoping that someone here might be able to help us. My dad is in the process of building a 38 Ford Woody. He's using a 38 standard from end, but he is missing the whole hood latch assembly (hood ornament, hood latch dowel, cam, tension spring, hood handle and base, etc).
I have searched everywhere, hoping to help him find the parts, but we've had no luck. Does anyone know where I might be able to find one? Or at least, if we can't get a hold of one, some sort of work-around for the hood latch.
Any suggestions would be greatly appreciated.
Thanks!
Chris
In addition to the above request, even a diagram of how the hood latch works would help us to build one, if necessary!
Thanks!
Chris
You might also try Stacy Brown in Arlington, TX. He might just have one in one of his 8 warehouses full of NOS stuff, mostly Ford.
The 1938 Ford hood latch on Ebay is for a 1938 deluxe or 1939 standard and he states he is using a 1938 standard front end. There is a difference between the two. be carefull what you buy.
The one on Ebay is "NOT" for a 39 Standard. It is for a 38 Standard or 38 Deluxe, maybe a 37. I don't know which but it's NOT 39 Standard.
I have an extra 38 Standard hood latch handle and shaft, dull chrome - $40.00 + actual shipping
Sorry no other hood latch parts
I need to see a picture of a completely assembled 1938 ford standard hood latch. That diagram is only helpful in identifying all the right parts.
Ok, went out to the Barn and dug out a 38 hood with a latch. Sorry about how dirty it is, but maybe it will help. There is a plate on the shaft that rotates with the handle. The plate moves into and out of a slot in a stud. The stud is on the grill side and sticks up through the hole in the hood.
