38 ford door window felt replacement
Jazzer
Hello,getting parts together for our coupe which will need new window channels and felt pieces. I have removed the inside felt from the window garnish molding from one side and stopped as I don't know whether I done wrong. The felt is off but the staples are still in place even after I straightened them out and gently pried with butter knives. Should the staples stay or go?
I need advice as to a vendor and what problems I am going to encounter.
Thank you any advice will be greatly appreciated,
Jay
The staples hold the felt to the garnish mold. You can remove them as the kit I bought had new ones. ( for my 39) kit also comes with small screws that you can use instead of the staples. (Which is what I used) most large venders should have them if they haven’t been discontinued.
