38 39 ford pickup / panel truck...
Ben, the pickup has a rounded corner at top rear and the panel has a pointed corner. Only difference I am aware of. Hope this helps!
If you can find a truck door(s) you can make them work, just fit them in the door openings on the panel, then make you a pattern to make a filler piece to weld onto the upper rear corner of the door to make it squared off like a panel truck door. Lot easier to find a door from a pickup or big truck and make it work.
