38/39 ford pickup flathead parts
38isthebestyear
Lubbock
TX
Price
200
1938–1939 Ford Pickup Parts Flathead / V8-60
Check out the Facebook ad in the link below
Shipping available FedEx is closest.
No boxes on hand; FedEx will package items (added cost).
If you want anything be ready to put a deposit down.
FOR SALE
1. Steering column w/ gearbox, horn button & column drop $300
Used, complete, untested.
2. Aftermarket link bar set $300
3. Steering knuckle / steering arms $75
4. One-ton lower grille aprons (pair) $250
Painted black, dented, one rust-through hole.
5. Half-ton lower grille aprons (pair) $200
6. Inner fender panels / aprons (pair) $125
7. Split windshield frame $300
Glass cracked, minor rust on frame edges.
8. Upper interior header panel (above windshield) $75
Previously repaired.
9. Metal floor pan, ’38–’39 pickup (new reproduction) $150
10. Flathead exhaust manifolds (pair) $70
11. Flathead starter $50
Disassembled, bolts loose.
12. Oil filter housing $75
13. V8-60 spark plug wire holder tubes (crab style) $40
14. Brake pedal assembly $75
15. Original shocks (pair) $50
Front or rear unknown.
16. Cowl vent screen $25
17. Cowl-to-grille support rods (pair) $25
18. Cooling fan 4-blade (fat belt) $100
Good condition.
19. Cooling fan 6-blade $50
20. Fuel filler neck $25
21. Fuel tank straps $25
22. Seat upper & lower pieces (set) $300
Original seat parts.
https://www.facebook.com/marketplace/item/1189369119844515/?mibextid=6ojiHh
