Drezin, The info I gave you is relevant to RHD 35-36. Virtually a direct bolt in... I understand, from reading other threads on here, that with LHD configured cars, fitting a 37-39 s/box into a 35-36 using the original mounting plate, that there may be interference between s/box and exhaust manifold. I understand that with LHD vehicles, you're better off to use the 37-39 steering box mounting plate. Requires drilling out three rivets and dealing with one spot weld to remove original plate.
