Anyone know if this is actually for a 37 pickup? Looks a little funky to me. Trying to get some extra support on the crank and maybe some extra cooling help, mostly so I don't slip again and poke a hole in my core.View attachment 518208
Sent from my SM-S908U1 using Tapatalk
It's my opinion that the diagram is not correct for the 1936 radiator shells. The 67-8240 radiator and grille shell is for all 1936 commercial (pickup) and truck. It has two holes to allow use on both the commercial and truck frames which have different crankshaft heights. The 51-8240 is only for the 1936 truck. It has a single hole which only aligns with the truck crankshaft and the "steps" allow clearance for the larger 51-8005-D radiator.
Attached are some images which I believe are correct.
