banjoQ
The cowl vent in my truck is stuck pretty bad with rust. I have been underneath the dash using penetrants trying to free up the mech. Can someone tell me, does the vent rise up and then tilt back or pivot on the two rear corners tilting back to open. Laying on your back looking up, its hard to tell. Trying to understand if there is a hinge point there. I can see the screen up there and figured it drops down to close off opening. One side seem to be loosening but the other is binding. Strong possibility rust has eaten the metal in this corner where it pivots upward. Spring tension has the vent sitting a bit cocked to one side in the opening. It seems that removing the spring on the handle would take any pressure off this assembly. But getting it back in place might be a problem. Anyone tackled this kind of problem before?
