Robert/Texas
When I bought this car last February, I noticed that the gap between the top of the steering column and the light switch/horn button seemed a little large but both the horn and lights worked fine so I didn't think much about it. Later when both horn and lights stopped working, I noticed that this gap had increased a good bit to over 1/4 inch. When I opened the switch at the bottom of the column, I found it stuffed with what appeared to be fresh chassis/wheel bearing grease so I cleaned it all out. (The steering box is/was filled with what appears to be transmission oil.) The c-clip was jammed to tight to get it out so I loosened the four screws that hold on the switch bracket and oil retainer. The c-clip was still jammed and the gap was still there so I gave up for the evening. The next morning I went back to work on it and something had relaxed and the gap between the steering column and switch/horn button was normal (tight) and both worked perfectly after I reassembled it. Now about six weeks later, the gap is growing again. At this point the lights work but the horn is "iffy".
I posted some about my problem on the old forum and thought I had the problem solved. Any further suggestions/ideas will be greatly appreciated.
