Is there a difference between a '37 and '38 headlight switch ?
After installing a '38 headlight switch in my '37 I can't get high beam.
Does the '38 have a floor mounted dimmer switch ?
The '37 has the high beam activated by turning the steering column switch all the way to the left.
With the '38 switch installed I can only turn the switch once to the left to activated the headlights - I can turn it no further - in order to get the high beam.
After looking in the various vender catalogues the list the '32 to 39 as the same ????
I've come to the conclusion that they're different ????
Where can I get a '37 switch ?
Thanks Rayzor
Thanks Rayzor
