37 Ford wiper assy
The early 37 sedan I purchased, as a "basket", didn't come with a wiper assy. I tried to find an electric assy, but all products I've found will not fit without some surgery to the supports for the windshield.
Does anyone have pictures of electric or vacuum assy for this car or know of an assy that will work in the 37 sedan with out cutting support brackets?
I'd appreciate any info you may have.
Thanks..... Socalsmith..........smithhn@verizon.net.
Unless there's some reason you don't want to go with original Trico wipers Kent Jaquith has what you need:
Kent Jaquith, 2633 SW Obsidian # 15, Redmond, Oregon (541) 923-4319
Clean-Sweep Windshield Wiper Motor Service, Sales and Rebuilding
Thanks guys for the info. I'd prefer to go with an electric wiper, so if the Mighty Wiper will work on both sides, I'll probably go that route. It appears to be the easiest install. My only concern is I'll be required to install one upside down to clear the header bracket and so it parks in the proper location.
Thanks again......... Socalsmith
Parking can be switched on a mighty wiper.
