Hi Guys, I have a stock 37 ford truck with 6 volt system. It has been running fine. Tried to start the other day, it turned over a few times but did not start. Pushed the starter button again and got a single click. Turn the key again and get one click. It has 6.6 volts at the battery. I thought it might be the starter and I gave it a few taps with a hammer, nothing. I replaced the solenoid, same thing. I then checked the volts at the starter and I only have 4.6 volts when I push the starter button. Do I have 2 bad solenoids? Can I bypass the solenoid and spark straight from battery to starter to see if it he starter is ok? As you can probably tell, I am new to these old trucks and could sure use some expert advise. Thanks!
