Struggling with 37 ford rear end assembly. believe got the pinion bearings correct and right gasket amount for ring gear preload .015 total between gaskets. But switching gaskets back and forth to get .003-.008 backlash
with the banjo tightened the pinion is almost too tight to turn and too tight to determin backlash. Start all over I guess.
