Trekemeyer
Could use some help with some help with removing ignition switch the electric partsthanks tom
I have found for re installing put the unit together on the bench and run tape around it to hold it together until you get the screws installed in the back .Otherwise you need all 10 fingers and some luck to put it back ,then remove the tape.
