Good evening, I have a 1937 60 hp flathead v8 that is starting to leak a bit of fuel around the top of the fuel pump. Is the fuel pump diaphragm in the 60 hp the same as the 85 hp flatheads of the same year? Thanks in advance, mindox
mindox,
The diaphragms are the same. The correct pump is the same as the
early version of the non glass bowl all metal pump except the top is clocked one hole
different. Let me know if I can assist...........cas5845@yahoo.com
Charlie ny
