I just purchased a 37 coupe with stock flathead. I am having some over heat issues and it acts like it's vapor locking when it heats up and then is very hard to keep running if you get it started again. If I understand correctly this engine has two thermostats, I assume one on each head. I was going to start there and then look into the water pump. Any suggestions for a first time flathead owner? Thanks
