37 dump truck, gas filler pipe remove
Walt Dupont--Me.
A friend just bought a 37 Ford dump truck, Nice truck, been restored 20yr's ago, been setting in a barn 20yr's. Gas tank full of rust and gunk. Wants to know how to remove the gas filler neck so he can remove the tank. He says it looks like a big nut with slots around it where it screws into the tank. Is that correct? Does it unscrew with some kind of a spanner wrench? Thanks Walt
My 34 pickup is the same, I kept soaking it with penetrating oil for several days & used a brass drift and a hammer and it broke loose, you will probably have to replace the lead gasket that goes between the flange and the tank when you reassemble. Hope it works for you.
Gary.
