Bubba, glad that you asked why. This is on a distrib that I just received back from you.
I had requested that you supply caps and rotor for the helmet that I sent along with points and setup. I received back the distrib with new points and used caps and rotor. The gap between the rotor and cap exceeded 60 thou. Hence the original post.
Perhaps someone was trying to be helpful but they were not. If you can't supply, say so. It's better than sending that which belongs in a landfill.
Also, who ever cleans the distib's up have them clean the recess that the rotor sits in and the oil tube that feeds that end. Attention to detail.
Rant over.
Yes, Bubba uses shrink tube on shaft. A nice touch.
Gary
