37 column drop
I recently bought a complete used 37 column, box etc. I’m wondering if someone can post pictures of the screws/bolts that hold it together? Mine appear to be all broken. But I’d like to confirm before I drill and try to remove them so I can get it off the column and apart. Thank you, Chris.
I have some detailed pictures of the column drop and the bolts that hold it to the dash. Would this help? I also have some pics showing an exploded view of the steering gear box, along with the mounting plate and bolts that fasten it to the frame.
gregg
OK, I am bored so thought I would attach some pics of the steering box assembly, etc.
gregg
Might as well include the column drop pics...
gregg
Where can I find ford part number 81A-3712 which is the metal box that screws on below the dropdown and holds the brush and bakelite part? I have a 1939 pickup and the part seems to not be reproduced. I've been told that it's the same part on 1938 and 1939 cars and trucks. I have all the other parts as they are readily available. I've seen then still attached to used dropdown columns but I already have all that.
LITTLE DEARBORN PARTS > http://littledearborn.com/
[FONT=&quot] Our Hours are Monday to Friday 9:00 am to 5:00 pm “Central Standard Time” [/FONT]
[FONT=&quot]Call our toll free number or For After Hours Ordering Select “Print and Fax” or “E-mail via Internet” below.[/FONT]​
[FONT=&quot]
[/FONT]
[FONT=&quot]1-888-282-2066 [/FONT]
[FONT=&quot]Print and Fax or Email via Internet[/FONT]​
[FONT=&quot]You can order 24 hours every day using “print and fax” or “Email via Internet”.[/FONT] [FONT=&quot]
[/FONT]
[FONT=&quot]Little Dearborn Parts, Inc.[/FONT][FONT=&quot] 2605 West Wayzata Blvd Suite 300, Long Lake, MN 55356
Toll Free: 1-888-282-2066 Phone: 612-331-2066 Fax: 612-331-3847[/FONT]
81A-3712 Ignition switch case 38-40 ea. 8
Check with Fred at Southside Obsolete or Michael Driskell at Third Gen Automotive for the twist off bolt.
Southside Obsolete 507 332-6789
Third Gen Automotive 844 327-5988
You sure helped me understand all this stuff better. Mine is a 36 but i don't think they are all that different. Thanks, Terry
gregg
Yep, they are similar. I believe Don Rogers posted some pic's of 36 stuff. I can dig those out if you are interested.
gregg
Gregg, Excellent!! Excellent job on your '37 steering column picture posting! With your permission, I would like to download all the information you have posted here to my files for future personal reference, and possibly to repost when someone else is seeking info, or has questions on the '37 steering column assembly.
I also have Don's '35-'36 steering column and column drop information saved in my files, which I frequently refer to when helping others.
You don’t need to drill the pinch bolt completely out. I drill a line of 1/16 in holes across the face and use a screwdriver to screw them out. I reuse the bolts.
I do the same thing, but occasionally I can't get that bolt to break loose using a handheld screwdriver, so I go to a handheld impact driver to get it to start turning, then use a regular flat blade screwdriver to bring that bolt completely out. Some penitrating oil on the treads can also be helpful.
