Attached is a picture of my 37-41 front end axle and perch bolt.
The perch bolt has two eyes (Bosses) the lower eye is a little wider than the top one. Not sure what this is for. This is different than the 41 deluxe sway bar stabilizer perch bolt set up where a swivel is attached.
Also notice the large bolt going through the axle which could be for a shock absorber.
I'm trying to figure how I will set up this front end up for the proper steering and shock absorber parts.
The spindles are 1937-41. I will be installing new king pins and hydraulic brakes and running 35 wire wheels under a 35 coupe 5 window.
Hope the picture is attached.
