36LB Rod Bearing questions...
Randy
I've got a '36LB engine that I acquired recently and discovered it had the wrong rod bearings in it. It had about 0.200" rod side clearance as it had the later full floating bearings without the flange.
I would like to find the correct rod bearings so I pulled a couple of rods out today. The bore of the two rods measure 2.222" and my book says they should measure 2.220", so I guess they've been bored 0.002" oversize. The crank is stamped R-010. I haven't measured it yet, but expect it to be 0.010" undersize.
Is there anyone that makes these flanged rod bearings in 0.002" oversize rod and 0.010" undersize crank or what is the solution? The rods seem a bit out of round but I guess the caps can be shaved and then the bore resized to + 0.002".
Thanks!
I got mine a couple of years back from REd Hamilton in fort bragg just north of San francisco
Also Sally Helger in New york I think
Lawrie
Thanks!
If you are going to have them re-sized , go for 2.220, not over-sized. Easier to get bearings.
When I did my '36 LB a couple summers ago, the vendor I bought the rod bearings from ended up not having a complete set of the flanged bearings, one set was missing. It as at this point that I found out that the flanged rod bearings have not been in production for decades, there is no NOS supplies to be had anywhere, and therefore it would be a real pain finding any. I spent about 2 days on the internet and on the phone before I found a guy in St. Cloud MN who had a stray pair of rod bearings in the size I needed. I will look through my stuff later on and see if I can find his name for you.
-Lyndon
When rebuilding a floating bearing I always hone in extra clearance in the rod bores. .002 is not excessive. However you must run the flanged bearings with this crank.
Ron:
Your comment got me to thinking: is it possible to install a later crank into one of the older pre '37 blocks, and then be able to use the more commonly available rod bearings?
I'm not sure, I know the 37-8 crank will fit but they use the flanged bearing too. Might want to contact Walt, I never worked on many of those stylr engines.
Randy, I sent you a p.m. I may have what you are needing, I have tons of bearings, flanged and other non flanged many sizes,rebuilt rods too. I m having health problems and I am thinning out the heard, I 'll probably never need all that I have.
Regards,
Fordestes
I would think that some manufacturer would have started making these flanged bearings again. I wonder why not?
I think you can even put a 4 inch crank in there. It seems like there is a clearance problem that requires some machine work either to the cheeks or the OD of the counterweights but I can't remember which. The snout is shorter on the early cranks too if I remember correctly but that wouldn't be too hard to modify. I'll have to check the Tex Smith flathead book to be sure. They modified a 37 block to up the CID to 255 so they would have more power & reliability for a 35 coupe running the Great American Race. They bored plum into the water jackets to sleeve the bores out to 3 3/16".
Kerby
