36 x member
1935-36 cross-members are shaped a little different in the motor mount area than the later ones, but believe they're all interchangeable. You didn't specify, so I'm assuming you're referring to the front (?).
Ratrod, are you talking about the front or rear cross member or the X member in the center of the frame?
I sent you a PM on 3/21 explaining that there was some difference between the very center part of the X member between '36 & '37, near where the front of the torque tube is located. One difference is where and how the brake cross shaft mounts, since '36 & '37 cross shafts are very different. If you are not doing mechanical brakes that difference would not be that important to you. Never received a response back from you so I assumed you understud my message.
