Lyndon
I'm wondering if a water pump is failing on my '36 Ford 21 stud. I don't have very many miles since a complete rebuild a couple years ago, but tonight on the way home from supper I noticed the temp gauge rising while stopped at a light. It fell back down a bit between lights, but started going back up again when I would sit still idling for a little while. The temp indicator in the dash usually never shows itself at all when driving (I'm using the original style temp gauge). When I got home and had a look, the back side of the pass. side water pump pulley was covered in black grease, and it had started to spit out into the surroundings a bit (pictures below may not show it very well). Does not appear to be leaking any coolant.
Is this the sign of a water pump going bad? Both pumps were bought as rebuilds from a reputable parts supplier.
Thanks,
Lyndon
Thanks,
Lyndon
