W wright-47 Member Apr 5, 2020 #1 Just wondering if anyone has used a sealed bearing for the input shaft and not used the wick seal? I would think the oil drain hole would have to be sealed. Stay safe and healthy.
S svm99 Well-known member Apr 5, 2020 #2 Use a ‘37 and later front bearing retainer with a seal. Seals are readily available. Use a shielded bearing.
