36 transmission
Danny/Texas
Just installed my transmission to the engine, but before installing both in the frame, I have a question. When in neutral, the transmission turns, but has a rough spot where it gets a little tight. It does turn but just tighter than the rest of the rotation. Do I have a problem, or will this work out. Its a 36 transmission case with synchonizers installed.
I don't know the history of your transmission, but if it were mine i would look in to the problem. Its alot easer to open up the trans now, than after its been installed into the chassis.....Ed
