36 temp gauge replacement
johndee138
I'm swapping out my 41 motor to a fresh built french block motor. The original temp gauge fitting is firmly stuck in the old head and attempts at removal have resulted in rounding off the flats on the fitting. Even vise grips won't budge the thing. I'm assuming I'll need to cut the wire that runs to the temp gauge. Is the probe bulb replaceable by a gauge restorer? Searches for a replacement gauge assembly haven't been very fruitful.
Any assistance will be greatly appreciated.
To bad you didn't have a tubing wrench. Yes line to the gauge can be repaired . Williamson's in AS or Wolf & Co in OH.
Are you using a '36 temp gauge with the capillary tube encased in a wire winding ?
If so the Wolf man is your guy. He did my '36 temp gage....primo....not quick or cheap
but 100% right.
Charlie ny
I did use a tubing wrench and the flats just gave way. Then the vise grip spun it into a round. The hollow bolt that seats the probe is screwed all the way down to the shoulder and didn't offer much surface to achieve purchase with either the wrench or the plier.
I need the Wolf man contact info please.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjru-HtlfXyAhWI4YUKHVsrDcAQFnoECAwQAw&url=https%3A%2F%2Fwww.antiqueinstrument.com%2F&usg=AOvVaw2snW0ONVJ-MBC1SFeM6drc
Here is a pic of the dash in my old '33.John Wolf did the temp unit .The face was done by Williamson's.Sorry I don't have a better pic.
Does it look like this? I had a new one in a box but can’t find it. This one may work
Do you have John Wolf's contact info?
Thanks in advance,
Pat Malone highbeams
(47malone@charter.net)
::JOHN WOLF and CO.INC :: Willoughby, restoration of ...Click on this and you will have their phone number
https://www.antiqueinstrument.com
The John Wolf Co. provides the functional and cosmetic restoration of gauges and instrumentation. We also restore antique auto and aircraft instruments.
You've visited this page 2 times. Last visit: 9/9/21
Contact Us
36470 Biltmore Pl #8 Willoughby, OH 44094, USA. Quick Contact.
Gallery
Home gallery. image. Copyright © 2021 John Wolf & Co. INC.
