36 sedan steering column key lock mechanism question
Ohc Joe
Ok so what does this mechanism on the column do i basically car the car somewhat apart not sure what this does also were the 2 wires on back side do
Thanks once again guys
Enjoy your evening
the key lock serves two purposes; when locked it locks the steering, also the ignition switch. The ignition switch is the toggle switch next to the keylock. the two wires coming from the backside ;one is from the battery, the other goes to the ignition coil. So, when the key is inserted into the lock and turned, it unlocks the steering and also you can then operate the toggle switch to turn on the ignition.
