36 Radiator Brackets
J & D
Callahan
Florida
I need the Brackets that bolt to the Radiator to mount the grille on a 36 Ford Coupe. They should be the same on all body styles. Thanks, John.
HUH? on my 36 coupe the radiator has 2 tabs as part of the shell around the core. The grill has 2 tabs that are part of the outside edge. They bolt together. Which are you missing?
I did not have a radiator, I got one off fordbarnr and it does not have any brackets. Thanks, John.
