36 pickup starter switch mounting
Scott H
My frame is missing the mounting holes for the foot actuated starter switch. I can see in the metal toe board where it needs to mount, but if I’m off by a little bit the switch probably won’t line up with the floorboard hole.
Can someone give me dimensions of where I should drill the holes?
I’m thinking this is a car frame that used a dash-mounted switch?
509432
509433
I’d always heard they were the same also. This floor starter switch was with the truck, but I have replaced the frame. Surely someone has a floor mounted switch and can locate the mounting holes?
CA Victoria - I may have to do that. It comes thru at an angle. I was thinking of securing the toe board and then using a vise grips to hood the switch on the frame, then drill holes.
Here are pictures of a 36 truck frame and a 36 car frame. The black frame with the section cut out is the original truck frame that had a lot of repairs on the kick up area so I used it for a donor to repair sections in a car frame (the frame with the bit of red paint) that was in better shape. There are two small holes in both frames that might be what you are referring to. I will put a tape measure on both and post a picture. Art
Thank you Art. The area I’m looking for is circled in your pic attached
Here are some pictures and measurements. The engine support rod hole on your frame is cut out so I also measured frome the hole in front of it. Art
Going off your trans mount you have a 37-39 frame. The x member is different you’ll need to align it with your toe board. And when using a later frame you’ll likely need to space the switch up 3/8 of a inch from the frame using washers so that it pokes through the toe board enough. I just went through this on the last two truck I did.
Thank you!
:cool:
