Maybe someone here has run into this and knows the answer.
I'm rebuilding the front suspension on my '36 pickup. I'm putting '39 juice brakes on it and pulling the mechanical brakes and hardware.
I want to R&R the king pins, and no longer need the cups on the pins to accommodate mechanical linkage. So, looking at Mac's, there is a part number 48-3111 which is the stock king pin kit.
But they also have a needle bearing version for 37-41 pickups, 78-3111-R.
Does that interchange for the '36 axle if you don't use mechanical brakes?
Mac's technician said that the pins of 78-3111-R are 5 1/4" totall height and a dia. of .690" (roughly 11/16"). Anybody know if those dimensions are good for a '36 spindle/axle?
