Voycey
Hi All
Apologies as this may have been covered in earlier posts. I suspect the horn button is the problem why the horn is not working, it was working previously. The Horn on my 36 has 2 wires going to it , one is active constantly , the other I guess is to ground. The horn works fine hooked direct to the battery but not when wired up. Does the horn itself need to be ground to the car when bolted to the inner guard? When you push the horn button does this then ground the actual horn ? All help appreciated.
