GOW Senior Member Sep 23, 2017 #1 looked around couldn't an answer. the horn on my 36 works also there are 4 positions you can turn the button....what do or did the different positions do? thanks
F Ford coupe Senior Member Sep 23, 2017 #2 You have off on high beam on low beam and on park lights ..Not in that order but that's it on my 36..
rotorwrench Well-known member Sep 23, 2017 #4 Ford used the light switch on the steering wheel for a long time but basically discontinued the practice in 1940.
1stford Senior Member Sep 23, 2017 #5 Strait up is off. 1 click to the right is parking lights. 1 click to the left is low beams and 2 clicks to the left is high beams.
Don Rogers Well-known member Sep 23, 2017 #7 Here's a diagram of the Light Sw./Horn Button showing the switch positions. Attachments 1935-36 Light Sw-Horn Button.jpg 37 KB · Views: 29
