Tom Morookian
I installed a Vintiques conversion to halogens, new bulbs, reflectors and ran 12 v power thru relays for both the high and low beams. Solid grounds for both buckets and direct ground wires. Kit came with the following bulbs: Candlepower H4 12V 60/55W part #4720
Low beam is about as bright as parking lights and hi beam about like what low beams should be. I ran a hot feed from the battery to the buckets and that makes no difference.
Do I need different bulbs?
