Voycey
Hi Guys
My fuel gauge has not worked ever, well maybe once many eons ago. I suspect the sender unit, is there a foolproof method of testing the unit.I have tried two units, there is power to the gauge and the feed to the sender unit is all good. I ran a direct wire to the gauge from the sender just in case to no avail. I tried running a ground wire from the screw on the sender unit then turned the switch momentarily, the gauge needle moved up towards full so the gauge seems to be working or did !!! Not sure of next step. Any help is always appreciated.
Cheers
Cheers
