36 ford truck coupling shaft
foleymech
1 1/2 ton Truck. 157 wheelbase. Need to get the center coupling shaft and tube out. Before I start are there any larger truck guys out there that can go through the process? Does the rear need to be disconnected to pull the rear shaft/ Torque tube back far enough to clear the center crossmember? I do want to remove the rear driveshaft to check the bearings.
Yes you need to pull the rear torque tube.(or the trans) The short inner shaft comes out first, it is splined at the front U-joint. Then remove the tin outer tube....
Would be a good time to check or replace the U-joints as well.
