When pressing new grease seals in rear brake drums should the seal be
pushed in until the metal portion comes into contact with the outer metal
portion of the wheel bearing? What is the correct starting location on the
axle for the key to be located before installation of drum. Should rear drums
be torqued and, if so, to how many foot pounds? Before reinstalling my speedo
gear on the torque tube should I fill the inner portion with grease or gear oil?
Thanks for any answers to my questions. I'm very close to being able to take
my humpback out for a test drive after spending most of the summer changing
the original 4.11 ring and pinion to a 3.78.
Peter
Peter
