36 ford p/u radio antenna
catskinner
Hello all
I'm new member from eastern Ky. needing help.
1--Did my truck have antenna mounted on cowl and which side?
2--Did Henry put the antenna under running board,which side and what did it look like?
catskinner, this section is mainly for questions and suggestions about how to use this forum. You will probably have better luck posting your question in the main forum under the "Early V8" forum.
