'36 Ford door window removal
mfurrow
I need help removing the passenger door window. When I roll the window all the way down I can see the rollers, but I can't figure out how to get the rollers out of the channel.
I figured it out. When the window is up, you can see a bolt in the cogwheel. When you remove that bolt, you can roll the window down far enough that the rollers come out of the channel.
