36 ford bumper braces
I just sent this email to another guy looking for front brackets. If he's not interested you can have them for the same deal.
I have a pair of 35 rear brackets that don't have the curve on them. I'm about to replace them with a correct 36 pair. If you have the real 36 bumper with the greater angle then you might keep looking.
Be careful which brackets you get. The 35 and 36 bumpers are different. The rolled over ends have a different angle. The outer brackets are different while the inner's are the same. The 36 outer has a slight bend downward at the outside end.
I have a pair of the outer brackets for a 36. One of these is a converted right to left side. That is, it was cut and welded to reverse the downward tilt. Here's a picture so you can see the curve. Also note the passenger side has 2 holes in it where the front license plate bracket was attached so now there are 2 holes on the passenger side too.
Probably cost me $20 to ship it because of the weight. Based on your 203 area code I guess your in Ct. I spend my summers in Mystic so, if you can wait, I could bring them up in May.
If you want them now, how about $75 delivered.
I prefer paypal but can do a check.
