36 Ford 5 window Chopped Coupe Project
mj40's
Boise
Idaho
Price
20
1936 Ford 5 window coupe that is all steel. Most of the hard work is already done. Just needs some finish sanding and blocking. Chopped 3.5" in front and 3" in rear, filled top, rear tail light housings shortened and molded to fenders. Rear bumper mounts removed.
Front fender filler panel welded to front fender and molded as one, for a nice smooth finish. Tilt column mounted, steering all hooked up, set-up for Chevrolet engine and trans., 8" Ford rear with triangulated four bar rear suspension and air ride (includes air bags only) TCI IFS with power rack and pinion. You can't find a nicer grille, includes all the S/S trim and a new Bob Drake bull nose, the hood is really nice and includes new S/S center strip and new hood side S/S, headlights are mint, S/S trim already polished, original lenses, includes new tail lights as well, have new brake pedal ***'ly with power booster. Garnish moldings all chopped to fit. I have many photos of the build as well. It wouldn't take much to get this car ready for summer cruising. $20K or trades considered.
Any questions you may contact Ken at (208) 891-0101
