The extra hole is there to accomodate the larger style radiator rod bracket (48-8140/1) if used. The Station continued to use the older small bracket (40-8140/10)
SEE ATTACHED IMAGE.
I believe that hole is for the button you push thru the insulating blanket under the dash,there are several holes scattered out fot the special push thru buttons.
