There are six blade versions that are the same diameter and hub configuration as your stock four blade fan. They pull more air through the radiator and over the engine but make a little more noise. I believe these six blade versions were used on some of the early v8 trucks. They are obviously not lighter than the four blade versions so they may not interest you. I'm sure there are modern flex blade fans that could be adapted to your stock fan mount generator that would be lighter in weight and provide more cfm of air flow.
