36 doors
ALS 36
In order too put 36ford fordor door on a 36 5coupe what needs too be done so that it fits correctly????????
Thankx big al
you have to grind the top corner also. if it,s a late 36 door the inside handle is in a different location then the 35. no proulbem unless you are going for judgeing then you would have to use the 35 inner panel whitch i have seen done. so if the 36 doors you are geting don,t have the inside parts you might have to mod to use the 35 stuff or if your changing one door you have to match the other if that maters to you .i hope you understand what i am trying to say
You can grind of the top edge of the door, but you then need to add back the inside lip of the door to look correct. I did this on my 36 5W Coupe.
